Seems if I’m editing a Detail View (e.g. creating a layout) I can’t add a column that’s driven by a formula.
Is there a reason for that?
Hmm you should be able to add the column. Can you give a gif example or something?
Ah, nevermind I’m wrong. You can edit the formula on the right hand side it seems.
Click the column type in the Hide|Show columns display, then click Add Formula.
