Filter rows, then sum
Hello everyone. I am a rank newbie.
From a table called “Field Service Report” with a date column called Date and a duration column called Hours, I want to total Hours for the current month only. This is the formula I came up with:
Sum(Filter([Field Service Report].Hours,month(last([Field Service Report].Date))=Month(today())))
The table is currently prefiltered to show only the current month’s entries. But I want the formula to work whether the table is prefiltered or not.
However, the formula is returning the total for the entire table (including the hidden rows). (1) What am I misunderstanding or doing wrong? (2) Any suggestions?
Hi Jim. Does this help?
[Table 1].Filter(Month(Date)=Month(Today())).Hours.Sum()
Worked perfectly. I see my syntax was way off the mark. Need to study formula writing. Thanks for your help!
I had a similar problem and your solution worked perfectly for me as well. Thanks Nick!
Thanks, Nick! I’ll try what I mean first next time—Coda is pretty intuitve.
