Please help with this formula for a filter (if this is possible).
I have two date fields, startdate and enddate.
For the filter I would like to use:
Include this row when:
If the field enddate is populated and its value is greater than today.
If the field enddate is not populated, then if the field startdate is greater than today.
I’m having a little trouble getting my head around this, but Coda has quickly became my go to app!
I used the <kbd> HTML Tag
(which is the tag used generally to display keys from a keyboard where one would think it’s needed… mostly on GitHub … At least, that’s where I found it)
