In my actual use case that won’t work. Actual formula is this horrible thing:
RunActions(
[All Outputs].AddRow(
[All Outputs].[CSV Source], thisRow,
[All Outputs].Header, true,
[All Outputs].[Column 1], thisRow.Table.Nth(1).Nth(1),
[All Outputs].[Column 2], thisRow.Table.Nth(1).Nth(2),
[All Outputs].[Column 3], thisRow.Table.Nth(1).Nth(3),
[All Outputs].[Column 4], thisRow.Table.Nth(1).Nth(4),
[All Outputs].[Column 5], thisRow.Table.Nth(1).Nth(5),
[All Outputs].[Column 6], thisRow.Table.Nth(1).Nth(6),
[All Outputs].[Column 7], thisRow.Table.Nth(1).Nth(7),
[All Outputs].[Column 8], thisRow.Table.Nth(1).Nth(8),
[All Outputs].[Column 9], thisRow.Table.Nth(1).Nth(9),
[All Outputs].[Column 10], thisRow.Table.Nth(1).Nth(10),
[All Outputs].[Column 11], thisRow.Table.Nth(1).Nth(11),
[All Outputs].[Column 12], thisRow.Table.Nth(1).Nth(12),
[All Outputs].[Column 13], thisRow.Table.Nth(1).Nth(13),
[All Outputs].[Column 14], thisRow.Table.Nth(1).Nth(14),
[All Outputs].[Column 15], thisRow.Table.Nth(1).Nth(15),
[All Outputs].[Column 16], thisRow.Table.Nth(1).Nth(16),
[All Outputs].[Column 17], thisRow.Table.Nth(1).Nth(17),
[All Outputs].[Column 18], thisRow.Table.Nth(1).Nth(18),
[All Outputs].[Column 19], thisRow.Table.Nth(1).Nth(19),
[All Outputs].[Column 20], thisRow.Table.Nth(1).Nth(20),
[All Outputs].[Column 21], thisRow.Table.Nth(1).Nth(21),
[All Outputs].[Column 22], thisRow.Table.Nth(1).Nth(22),
[All Outputs].[Column 23], thisRow.Table.Nth(1).Nth(23),
[All Outputs].[Column 24], thisRow.Table.Nth(1).Nth(24),
[All Outputs].[Column 25], thisRow.Table.Nth(1).Nth(25),
[All Outputs].[Column 26], thisRow.Table.Nth(1).Nth(26),
[All Outputs].[Column 27], thisRow.Table.Nth(1).Nth(27),
[All Outputs].[Column 28], thisRow.Table.Nth(1).Nth(28),
[All Outputs].[Column 29], thisRow.Table.Nth(1).Nth(29),
[All Outputs].[Column 30], thisRow.Table.Nth(1).Nth(30),
[All Outputs].[Column 31], thisRow.Table.Nth(1).Nth(31),
[All Outputs].[Column 32], thisRow.Table.Nth(1).Nth(32),
[All Outputs].[Column 33], thisRow.Table.Nth(1).Nth(33),
[All Outputs].[Column 34], thisRow.Table.Nth(1).Nth(34),
[All Outputs].[Column 35], thisRow.Table.Nth(1).Nth(35),
[All Outputs].[Column 36], thisRow.Table.Nth(1).Nth(36),
[All Outputs].[Column 37], thisRow.Table.Nth(1).Nth(37),
[All Outputs].[Column 38], thisRow.Table.Nth(1).Nth(38),
[All Outputs].[Column 39], thisRow.Table.Nth(1).Nth(39),
[All Outputs].[Column 40], thisRow.Table.Nth(1).Nth(40),
[All Outputs].[Column 41], thisRow.Table.Nth(1).Nth(41),
[All Outputs].[Column 42], thisRow.Table.Nth(1).Nth(42),
[All Outputs].[Column 43], thisRow.Table.Nth(1).Nth(43),
[All Outputs].[Column 44], thisRow.Table.Nth(1).Nth(44),
[All Outputs].[Column 45], thisRow.Table.Nth(1).Nth(45),
[All Outputs].[Column 46], thisRow.Table.Nth(1).Nth(46),
[All Outputs].[Column 47], thisRow.Table.Nth(1).Nth(47),
[All Outputs].[Column 48], thisRow.Table.Nth(1).Nth(48),
[All Outputs].[Column 49], thisRow.Table.Nth(1).Nth(49),
[All Outputs].[Column 50], thisRow.Table.Nth(1).Nth(50),
[All Outputs].[Column 51], thisRow.Table.Nth(1).Nth(51),
[All Outputs].[Column 52], thisRow.Table.Nth(1).Nth(52),
[All Outputs].[Column 53], thisRow.Table.Nth(1).Nth(53),
[All Outputs].[Column 54], thisRow.Table.Nth(1).Nth(54),
[All Outputs].[Column 55], thisRow.Table.Nth(1).Nth(55),
[All Outputs].[Column 56], thisRow.Table.Nth(1).Nth(56),
[All Outputs].[Column 57], thisRow.Table.Nth(1).Nth(57),
[All Outputs].[Column 58], thisRow.Table.Nth(1).Nth(58),
[All Outputs].[Column 59], thisRow.Table.Nth(1).Nth(59),
[All Outputs].[Column 60], thisRow.Table.Nth(1).Nth(60),
[All Outputs].[Column 61], thisRow.Table.Nth(1).Nth(61),
[All Outputs].[Column 62], thisRow.Table.Nth(1).Nth(62),
[All Outputs].[Column 63], thisRow.Table.Nth(1).Nth(63),
[All Outputs].[Column 64], thisRow.Table.Nth(1).Nth(64),
[All Outputs].[Column 65], thisRow.Table.Nth(1).Nth(65),
[All Outputs].[Column 66], thisRow.Table.Nth(1).Nth(66),
[All Outputs].[Column 67], thisRow.Table.Nth(1).Nth(67),
[All Outputs].[Column 68], thisRow.Table.Nth(1).Nth(68),
[All Outputs].[Column 69], thisRow.Table.Nth(1).Nth(69),
[All Outputs].[Column 70], thisRow.Table.Nth(1).Nth(70),
[All Outputs].[Column 71], thisRow.Table.Nth(1).Nth(71),
[All Outputs].[Column 72], thisRow.Table.Nth(1).Nth(72),
[All Outputs].[Column 73], thisRow.Table.Nth(1).Nth(73),
[All Outputs].[Column 74], thisRow.Table.Nth(1).Nth(74),
[All Outputs].[Column 75], thisRow.Table.Nth(1).Nth(75),
[All Outputs].[Column 76], thisRow.Table.Nth(1).Nth(76),
[All Outputs].[Column 77], thisRow.Table.Nth(1).Nth(77),
[All Outputs].[Column 78], thisRow.Table.Nth(1).Nth(78),
[All Outputs].[Column 79], thisRow.Table.Nth(1).Nth(79),
[All Outputs].[Column 80], thisRow.Table.Nth(1).Nth(80),
[All Outputs].[Column 81], thisRow.Table.Nth(1).Nth(81),
[All Outputs].[Column 82], thisRow.Table.Nth(1).Nth(82),
[All Outputs].[Column 83], thisRow.Table.Nth(1).Nth(83),
[All Outputs].[Column 84], thisRow.Table.Nth(1).Nth(84),
[All Outputs].[Column 85], thisRow.Table.Nth(1).Nth(85),
[All Outputs].[Column 86], thisRow.Table.Nth(1).Nth(86),
[All Outputs].[Column 87], thisRow.Table.Nth(1).Nth(87),
[All Outputs].[Column 88], thisRow.Table.Nth(1).Nth(88),
[All Outputs].[Column 89], thisRow.Table.Nth(1).Nth(89),
[All Outputs].[Column 90], thisRow.Table.Nth(1).Nth(90),
[All Outputs].[Column 91], thisRow.Table.Nth(1).Nth(91),
[All Outputs].[Column 92], thisRow.Table.Nth(1).Nth(92),
[All Outputs].[Column 93], thisRow.Table.Nth(1).Nth(93),
[All Outputs].[Column 94], thisRow.Table.Nth(1).Nth(94),
[All Outputs].[Column 95], thisRow.Table.Nth(1).Nth(95),
[All Outputs].[Column 96], thisRow.Table.Nth(1).Nth(96),
[All Outputs].[Column 97], thisRow.Table.Nth(1).Nth(97),
[All Outputs].[Column 98], thisRow.Table.Nth(1).Nth(98),
[All Outputs].[Column 99], thisRow.Table.Nth(1).Nth(99),
[All Outputs].[Column 100], thisRow.Table.Nth(1).Nth(100),
[All Outputs].[Column 101], thisRow.Table.Nth(1).Nth(101),
[All Outputs].[Column 102], thisRow.Table.Nth(1).Nth(102),
[All Outputs].[Column 103], thisRow.Table.Nth(1).Nth(103),
[All Outputs].[Column 104], thisRow.Table.Nth(1).Nth(104),
[All Outputs].[Column 105], thisRow.Table.Nth(1).Nth(105),
[All Outputs].[Column 106], thisRow.Table.Nth(1).Nth(106),
[All Outputs].[Column 107], thisRow.Table.Nth(1).Nth(107),
[All Outputs].[Column 108], thisRow.Table.Nth(1).Nth(108),
[All Outputs].[Column 109], thisRow.Table.Nth(1).Nth(109),
[All Outputs].[Column 110], thisRow.Table.Nth(1).Nth(110),
[All Outputs].[Column 111], thisRow.Table.Nth(1).Nth(111),
[All Outputs].[Column 112], thisRow.Table.Nth(1).Nth(112),
[All Outputs].[Column 113], thisRow.Table.Nth(1).Nth(113),
[All Outputs].[Column 114], thisRow.Table.Nth(1).Nth(114),
[All Outputs].[Column 115], thisRow.Table.Nth(1).Nth(115),
[All Outputs].[Column 116], thisRow.Table.Nth(1).Nth(116),
[All Outputs].[Column 117], thisRow.Table.Nth(1).Nth(117),
[All Outputs].[Column 118], thisRow.Table.Nth(1).Nth(118),
[All Outputs].[Column 119], thisRow.Table.Nth(1).Nth(119),
[All Outputs].[Column 120], thisRow.Table.Nth(1).Nth(120),
[All Outputs].[Column 121], thisRow.Table.Nth(1).Nth(121),
[All Outputs].[Column 122], thisRow.Table.Nth(1).Nth(122),
[All Outputs].[Column 123], thisRow.Table.Nth(1).Nth(123),
[All Outputs].[Column 124], thisRow.Table.Nth(1).Nth(124),
[All Outputs].[Column 125], thisRow.Table.Nth(1).Nth(125),
[All Outputs].[Column 126], thisRow.Table.Nth(1).Nth(126),
[All Outputs].[Column 127], thisRow.Table.Nth(1).Nth(127),
[All Outputs].[Column 128], thisRow.Table.Nth(1).Nth(128),
[All Outputs].[Column 129], thisRow.Table.Nth(1).Nth(129),
[All Outputs].[Column 130], thisRow.Table.Nth(1).Nth(130)
thisRow.Table.Slice(2).FormulaMap(
[All Outputs].[Column 1], thisRow.Table.Nth(1),
[All Outputs].[Column 2], thisRow.Table.Nth(2),
[All Outputs].[Column 3], thisRow.Table.Nth(3),
[All Outputs].[Column 4], thisRow.Table.Nth(4),
[All Outputs].[Column 5], thisRow.Table.Nth(5),
[All Outputs].[Column 6], thisRow.Table.Nth(6),
[All Outputs].[Column 7], thisRow.Table.Nth(7),
[All Outputs].[Column 8], thisRow.Table.Nth(8),
[All Outputs].[Column 9], thisRow.Table.Nth(9),
[All Outputs].[Column 10], thisRow.Table.Nth(10),
[All Outputs].[Column 11], thisRow.Table.Nth(11),
[All Outputs].[Column 12], thisRow.Table.Nth(12),
[All Outputs].[Column 13], thisRow.Table.Nth(13),
[All Outputs].[Column 14], thisRow.Table.Nth(14),
[All Outputs].[Column 15], thisRow.Table.Nth(15),
[All Outputs].[Column 16], thisRow.Table.Nth(16),
[All Outputs].[Column 17], thisRow.Table.Nth(17),
[All Outputs].[Column 18], thisRow.Table.Nth(18),
[All Outputs].[Column 19], thisRow.Table.Nth(19),
[All Outputs].[Column 20], thisRow.Table.Nth(20),
[All Outputs].[Column 21], thisRow.Table.Nth(21),
[All Outputs].[Column 22], thisRow.Table.Nth(22),
[All Outputs].[Column 23], thisRow.Table.Nth(23),
[All Outputs].[Column 24], thisRow.Table.Nth(24),
[All Outputs].[Column 25], thisRow.Table.Nth(25),
[All Outputs].[Column 26], thisRow.Table.Nth(26),
[All Outputs].[Column 27], thisRow.Table.Nth(27),
[All Outputs].[Column 28], thisRow.Table.Nth(28),
[All Outputs].[Column 29], thisRow.Table.Nth(29),
[All Outputs].[Column 30], thisRow.Table.Nth(30),
[All Outputs].[Column 31], thisRow.Table.Nth(31),
[All Outputs].[Column 32], thisRow.Table.Nth(32),
[All Outputs].[Column 33], thisRow.Table.Nth(33),
[All Outputs].[Column 34], thisRow.Table.Nth(34),
[All Outputs].[Column 35], thisRow.Table.Nth(35),
[All Outputs].[Column 36], thisRow.Table.Nth(36),
[All Outputs].[Column 37], thisRow.Table.Nth(37),
[All Outputs].[Column 38], thisRow.Table.Nth(38),
[All Outputs].[Column 39], thisRow.Table.Nth(39),
[All Outputs].[Column 40], thisRow.Table.Nth(40),
[All Outputs].[Column 41], thisRow.Table.Nth(41),
[All Outputs].[Column 42], thisRow.Table.Nth(42),
[All Outputs].[Column 43], thisRow.Table.Nth(43),
[All Outputs].[Column 44], thisRow.Table.Nth(44),
[All Outputs].[Column 45], thisRow.Table.Nth(45),
[All Outputs].[Column 46], thisRow.Table.Nth(46),
[All Outputs].[Column 47], thisRow.Table.Nth(47),
[All Outputs].[Column 48], thisRow.Table.Nth(48),
[All Outputs].[Column 49], thisRow.Table.Nth(49),
[All Outputs].[Column 50], thisRow.Table.Nth(50),
[All Outputs].[Column 51], thisRow.Table.Nth(51),
[All Outputs].[Column 52], thisRow.Table.Nth(52),
[All Outputs].[Column 53], thisRow.Table.Nth(53),
[All Outputs].[Column 54], thisRow.Table.Nth(54),
[All Outputs].[Column 55], thisRow.Table.Nth(55),
[All Outputs].[Column 56], thisRow.Table.Nth(56),
[All Outputs].[Column 57], thisRow.Table.Nth(57),
[All Outputs].[Column 58], thisRow.Table.Nth(58),
[All Outputs].[Column 59], thisRow.Table.Nth(59),
[All Outputs].[Column 60], thisRow.Table.Nth(60),
[All Outputs].[Column 61], thisRow.Table.Nth(61),
[All Outputs].[Column 62], thisRow.Table.Nth(62),
[All Outputs].[Column 63], thisRow.Table.Nth(63),
[All Outputs].[Column 64], thisRow.Table.Nth(64),
[All Outputs].[Column 65], thisRow.Table.Nth(65),
[All Outputs].[Column 66], thisRow.Table.Nth(66),
[All Outputs].[Column 67], thisRow.Table.Nth(67),
[All Outputs].[Column 68], thisRow.Table.Nth(68),
[All Outputs].[Column 69], thisRow.Table.Nth(69),
[All Outputs].[Column 70], thisRow.Table.Nth(70),
[All Outputs].[Column 71], thisRow.Table.Nth(71),
[All Outputs].[Column 72], thisRow.Table.Nth(72),
[All Outputs].[Column 73], thisRow.Table.Nth(73),
[All Outputs].[Column 74], thisRow.Table.Nth(74),
[All Outputs].[Column 75], thisRow.Table.Nth(75),
[All Outputs].[Column 76], thisRow.Table.Nth(76),
[All Outputs].[Column 77], thisRow.Table.Nth(77),
[All Outputs].[Column 78], thisRow.Table.Nth(78),
[All Outputs].[Column 79], thisRow.Table.Nth(79),
[All Outputs].[Column 80], thisRow.Table.Nth(80),
[All Outputs].[Column 81], thisRow.Table.Nth(81),
[All Outputs].[Column 82], thisRow.Table.Nth(82),
[All Outputs].[Column 83], thisRow.Table.Nth(83),
[All Outputs].[Column 84], thisRow.Table.Nth(84),
[All Outputs].[Column 85], thisRow.Table.Nth(85),
[All Outputs].[Column 86], thisRow.Table.Nth(86),
[All Outputs].[Column 87], thisRow.Table.Nth(87),
[All Outputs].[Column 88], thisRow.Table.Nth(88),
[All Outputs].[Column 89], thisRow.Table.Nth(89),
[All Outputs].[Column 90], thisRow.Table.Nth(90),
[All Outputs].[Column 91], thisRow.Table.Nth(91),
[All Outputs].[Column 92], thisRow.Table.Nth(92),
[All Outputs].[Column 93], thisRow.Table.Nth(93),
[All Outputs].[Column 94], thisRow.Table.Nth(94),
[All Outputs].[Column 95], thisRow.Table.Nth(95),
[All Outputs].[Column 96], thisRow.Table.Nth(96),
[All Outputs].[Column 97], thisRow.Table.Nth(97),
[All Outputs].[Column 98], thisRow.Table.Nth(98),
[All Outputs].[Column 99], thisRow.Table.Nth(99),
[All Outputs].[Column 100], thisRow.Table.Nth(100),
[All Outputs].[Column 101], thisRow.Table.Nth(101),
[All Outputs].[Column 102], thisRow.Table.Nth(102),
[All Outputs].[Column 103], thisRow.Table.Nth(103),
[All Outputs].[Column 104], thisRow.Table.Nth(104),
[All Outputs].[Column 105], thisRow.Table.Nth(105),
[All Outputs].[Column 106], thisRow.Table.Nth(106),
[All Outputs].[Column 107], thisRow.Table.Nth(107),
[All Outputs].[Column 108], thisRow.Table.Nth(108),
[All Outputs].[Column 109], thisRow.Table.Nth(109),
[All Outputs].[Column 110], thisRow.Table.Nth(110),
[All Outputs].[Column 111], thisRow.Table.Nth(111),
[All Outputs].[Column 112], thisRow.Table.Nth(112),
[All Outputs].[Column 113], thisRow.Table.Nth(113),
[All Outputs].[Column 114], thisRow.Table.Nth(114),
[All Outputs].[Column 115], thisRow.Table.Nth(115),
[All Outputs].[Column 116], thisRow.Table.Nth(116),
[All Outputs].[Column 117], thisRow.Table.Nth(117),
[All Outputs].[Column 118], thisRow.Table.Nth(118),
[All Outputs].[Column 119], thisRow.Table.Nth(119),
[All Outputs].[Column 120], thisRow.Table.Nth(120),
[All Outputs].[Column 121], thisRow.Table.Nth(121),
[All Outputs].[Column 122], thisRow.Table.Nth(122),
[All Outputs].[Column 123], thisRow.Table.Nth(123),
[All Outputs].[Column 124], thisRow.Table.Nth(124),
[All Outputs].[Column 125], thisRow.Table.Nth(125),
[All Outputs].[Column 126], thisRow.Table.Nth(126),
[All Outputs].[Column 127], thisRow.Table.Nth(127),
[All Outputs].[Column 128], thisRow.Table.Nth(128),
[All Outputs].[Column 129], thisRow.Table.Nth(129),
[All Outputs].[Column 130], thisRow.Table.Nth(130)
As you can no doubt tell, a related issue is that I don’t have programmatic control over the number of columns in a table.
