Hey! I’m currently working on a coda formula pack. The response of this is an object but the I would like to put every key of the object in a different column. Is it that possible?
Hi @Katherine_Pacheco - Welcome to the Coda community! Unfortunately you can’t force your Pack to push the fields into different columns, but the user of your Pack can do this with formulas.
