IsText() returns false for bulleted lists, regardless of whether generated with BulletedList or manually by typing “*” and text. This was unexpected behavior for me, although it may be expected for some use cases. Is there an alternative to IsText() that will work for this?
Try using toText() and then apply isText()
Hi Christian,
I already thought of that. I’m pretty sure that .ToText().IsText() would always return true, regardless of input value – even numbers or row records.
