Min() - Max() - how to get what's between?
Hi
I have a list with months Jan to Dec
The Min month = Jan
The Max month = Mar
How can I get a list that includes the missing months, like this case Feb?
The result I should like to get is: Jan, Feb, Mar
If you have suggestions how and or where to find solutions, it would be great
While searching on Google, I get mainly the approach in Excel, but…
In the doc you see the use case :bulb:
Thanks in advance for your time,
//JP
Hi JP,
You should be able to use the sequence function to do this.
First, you’ll need to extract the month number from the start date (Month(Date)), then you can do:
Sequence([Start Month], [End Month],1).FormulaMap(Date([Year],CurrentValue,1)).
Will you need this to work from one year to the next?
If so, it’ll be a bit more complicated, you’ll probably need to work out what the months are as an offset from a specific ‘zero’ date, sequence the months in that way, and then convert them back relative to that ‘zero’ date.
I can help with this, but it will take me more time than I have available right now.
Joe
Dear @Joe_Innes,
Thanks coming back to my question for what I still didn’t find a solution.
You think very well ahead :brain:, you are right :ok_hand:, I will need to cover more years.:calendar:
In below table I added the month number and the year (with formulas)
With respect for your time, I will be patient and look forward to your input.
Thank you sooo much,
//JP
Sequence(StartDate,EndDate,1).FormulaMap(CurrentValue.ToDate().Year() + ":" + CurrentValue.ToDate().Month()).Unique().BulletedList()
This should give you a bulleted list of Year: Month from StartDate to EndDate
If you want actual date values, this will work too:
    .FormulaMap(CurrentValue.DateTimeTruncate("month"))
    .Unique()
Here’s an example:
Thank you All
The detailed explanation creates high value for the community and onboarding users.
I am working to get all formulas in a table, with links to the formula pages and I will connect formulas used to content like this and also a relationship to the applicable guidelines.
When it gets shaped, I will share to decide if it would be something to add to the learning section.
Kind regards,
//JP
Glad that the folks above provided a solution, and apologies I didn’t get round to it earlier!
