Noticed there wasn’t anything like this so I decided to make my own:
It’s actually really simple and uses an existing npm package under the hood.
Hope this will be useful to someone aswell!
Just curious, does it work like the EncodeForURL formula?
Thank you for asking!
It’s purpose is very different. EncodeForURL keeps the original string recoverable - you can decode it later.
Slug is a pretty/simplified version of an otherwise URL-unfriendly string/text.
Imagine if you’re using Coda as a backend for your blog (as a CMS), and you want to create a new post titled “This is the #1 post!”. You probably want the URL for that post to be pretty (there is also a SEO benefit) so you’d slugify it and get “this-is-the-1-post”. You can then use this slug for an URL to your blog post, e.g. myblog.com/this-is-the-1-post
In comparison, if you run the same string through EncodeForURL, you get “This%20is%20the%20%231%20post%21”. As you can tell this is pretty much unreadable without first decoding it.
