Went back to make some updates to an older CLI Pack, and now Typescript is mad about a bunch of things it wasn’t mad about before. (I don’t know Typescript very well, and at first it seemed like the compiler was cool with my sprinkle-types-in-some-places-but-not-everywhere approach, but now it’s complaining of things like
Unrecognized key(s) in object
null is not assignable to type ...
etc
Can I tell TS to chill out a bit with a config or something?
It’s a nuclear option, but you can disable all type checking in a file by including this line somewhere:
// @ts-nocheck
Alternatively, using @ts-ignore to just disable the checking on the following line.
let a = "abc";
// @ts-ignore
a = 123;
In most cases TypeScript is telling you something useful about how you could improve your code, but it doesn’t always do it in a way that’s easy to understand.
It’s a good question, and I don’t know for sure. How long ago did you last build the code? If it was during our beta we could have changed some settings since then.
