Is there already a way to hide a row when clicking a button? If so, can anyone help me out? Thanks!
You can add a column called “Hidden” which is a checkbox.
Filter your table by the hidden column’s “unchecked” state.
Then create a button “Hide me” to check [thisRow].Hidden = true
I would also suggest making a button outside of the table that does:
Modify Rows > Table > All Rows > Hidden = false.
Brilliant! Thank you Joshua.
