Good day, try to figure out - is it possible to make button or action that add row to other table, between dates.
Example what i try to automate
Dear @daniil,
Would you mind to update the sharing setting of your embedded doc so that everyone can play with it.
Also can you take a look at and see if it helps - Please feel free to make a copy of this doc
Just made. Thanks
Support give me solution for this. Its amazing!
