Hi all. When I publish a doc, it seems like the “author” meta data is shown in the share link preview - even if I have that option disabled in the doc itself. Is there anyway to disable that data from being shown?
Hi Jeff,
If I understand your question correctly, you should be able to achieve this by publishing your doc on a custom domain. This help article here has more information on that. Hope that helps!
Best,
James
