Notify when row is updated is failing to run. Testing the rule works fine but keep getting this notification
Dear @Christine_Haynes,
Welcome in the Coda community
To have better chances to receive adequate support, I recommend to share a dummy of your document where is the problem(s) and explained what you expect to happen.
