Hello there! I’m having issues with an automatization. I think everything is correct so I don’t know if it’s something related with coda. I’m triying to get a notification every time someone fills my form. So far I have this (please see the screenshot) when I test the rule works fine. However, If I fill out the form and the new row is created nothing happens, I don’t get any notification.
Thats because you are using a “row changed” trigger instead of a “row added” trigger.
That kind you are after does not exist, but you can simulate it like this!
Ty so much Scott, works pretty good ![]()
