Best Practices for Page Header Images
If one doesn’t want to use the Unsplash integration for adding a page header, what are the best practices for uploading custom images?
What aspect ratio is ideal?
What dimensions are ideal?
What’s ideal for image size so that images load quickly?
Any tips for how to have text appear centered in a header image across different monitor sizes and mobile?
Been doing some trial and error. Not sure finding right combo.
Thank you. :pray:
Hey there @Colleen_Brady! Great question! I know the experimenting can get annoying over time. It looks like the dimensions should be1500x380. As for the text, it should hold up if you center the text in the middle of the cover image. I know that doesn’t solve everything but I hope it helps a bit!
