Are you wanting to show an image header for the page or are you looking to show images full width for each row of a table?
The options for a full page header are above the section title if you hover there on desktop, you’ll see an “Options” button to click.
For a table, on desktop, you can change the table to a card layout, then use the card layout settings to choose the image URL column and set the image to be “top”. Then you can change it back to a table, and it should stay for mobile.
This is still a really big problem. Currently, if you select one of the nicely formatted modal layouts, for instance, to display a blog post from a list, you’ll see a nice, full-width hero image on the desktop view. However, on mobile, it will be tiny! Not at all intuitive. For now, I’ve implemented a workaround by using the hidden formula below to expose the image url and set height and width properties via the image( ) function.
Clearly, though, this isn’t ideal, since I’m coloring outside the lines. Please implement a native fix for this! Or, if there’s already one and I’m just overlooking, please assist. Thanks so much, @BenLee
Thanks for posting @TSStrickand1. I’ve passed this along to the team as it might be a bug. Not sure when we’ll be able to get some attention to it, but it’s logged in our internal tracker now.
