I want the result to look like this:
- Delrin Black - 2
- Micarta Black - 1
- Ultem - 1
But somehow I am not seeing how to do it with the Unique()
This works:
This works:
Hi @Support_MMVapors
So, I think this is what you’re looking for:
(See the sample below
Table.[Body Material].Unique().FormulaMap(
Concatenate(
CurrentValue,
Table.Filter([Body Material] = CurrentValue).Count()
).BulletedList()
And what it does is :
It creates a list of the unique material from the table (like you did in your last screenshot)
This returns a list of text values where each item in the list is stored as CurrentValue and in this case, this list looks like this :
Material 1,Material 2,Material 3
Then, like you did, for each item in the list (FormulaMap()), I ask the formula to Concatenate() :
1 - the CurrentValue (which is each material in the list)
2 - the separator " - "
3 - Table.Filter([Body Material] = CurrentValue).Count()
where
Takes the table and counts how many [Body Material] ([Body Material] is here CurrentValue.[Body Material]) are equal to CurrentValue (CurrentValue here, is the specific item in the list from Table.[Body Material].Unique()
And as FormulaMap() always returns a list all that’s left is to BulletedList() the result ![]()
Now, I think that instead of using text values to get to that result, maybe you could use a LookUp field ![]()
If you look at the sample below, I created a table for the Materials and linked that table to another table where I randomly selected a material per row.
In my Materials table I can then count how many times each material has been selected in the table and the formula can then become simply this :
Materials.FormulaMap(
Concatenate(
CurrentValue.Name," - ",CurrentValue.[Materials - Count]
).BulletedList()
It still works in a similar way than the previous one but by using a lookup to store your various materials, it gets easier to correct if there’s any mistake
Thank you so much! I was staring at my formula the other day for the longest time and I just did not see it! ![]()
No problem @Support_MMVapors
… I’m very glad to know this helped as …
I know that feeling
… probably a little bit too well
