I have a form that I have shared with a client to enable them to submit content ideas for their social media channels.
When they used the form they were prompted to sign up for Coda, which then got confusing for them because they gained access to the doc version of the form, which was only ‘comment’ enabled so they couldn’t complete the form.
Is there a way around this to make it less confusing for them?
Thanks for the response. This makes sense, except I have only shared the form with the client and this doesn’t have the option to switch the modal on or off:
Another possibility in this case, could be that the required login option is activated. In the options of the form, you can change in the privacy part.
