CMD+SHIFT+H is the default shortcut for “Home” on Google Chrome and Brave. Would have less issues if “OPT+SHIFT+H” was used.
Other people have also requested this on Windows for different reasons.
Thanks for sharing this feedback @Connor_McCormick.
I’ve got this added to our internal tracker so we can go over it when we work on shortcuts.
I am confused about the shortcut CMD+SHIFT+H…once I enter those keystrokes, how do I switch the font color on selected text from, say, black to red, or red to green? Or is there a better way to do this?
The color settings will be the ones that you last used. There isn’t a way to use keyboard shortcuts to go through the color options that I know of.
