Hey Coda crew,
I’m working on building a RSS feed (xml file) using Coda and I’m almost there but for some formulas, I need a bit of assistance. Basically I need some help in writing a formula which takes values from columns, determine what type of value it is and returns a result in a specific format - yes, this sounds a bit vague so I will show you what I mean in a crude example;
So basically the OUTPUT column is an element in my RSS feed that combines lists of names and/or creates “a links” if there is a weblink entered for a particular person. I started on a solution using a whole bunch of If() statements but it became unwieldy and my brain melted. I really just need to be steered in the right direction if somebody has the time to take a look for me.
Appreciate any help you have to offer.
Cheers
Dean
