I’m building a private Pack that pulls information from an API into a Coda table. Most of the information that the API returns is a string or a number, but there’s one field that’s an array. For example:
{ "items": [
"stringProperty": "String",
"numberProperty": 2,
"arrayProperty": ["cat", "dog", "fish", "bird"],
Where the arrayProperty could contain any number of values.
I think I’ve got my schema set up to handle the array (or at least the Pack isn’t returning an error — hat tip to Pack formula resultType of object with property type of StringArray? for that one). The schema looks like this:
const mySchema = coda.makeObjectSchema({
properties: {
stringProperty: { type: coda.ValueType.String },
numberProperty: {
type: coda.ValueType.Number,
fromKey: "id",
arrayProperty: {
type: coda.ValueType.Array,
items: { type: coda.ValueType.String }
On the resulting table when I install the Pack, the arrayProperty column’s type is Text.
What I’d now like to do is create a related table that shows all the arrayProperty items individually, and be able to create another column in the related table that counts the unique uses of each item (how many times “cat” appears overall, how many times “dog” appears, etc.).
I have tried changing the arrayProperty column to column type “Relation” and “Create a new table,” which does seem to make a table of the individual array items; however, when I create a number column with a formula (First Table.filter(arrayProperty = thisrow.arrayProperty).Count()), I only get results for rows with cat or dog in them individually (so, given cat and cat, dog, the formula column returns just 1 for cat and 0 for dog, not 2 and 1 respectively).
I figure this is just a matter of my configuring something wrong. Can anyone point me in the right direction? Thanks!
