I cannot get a “Count if” formula to work.  More clear explanation in screenshot below but I will try and summarize it here as well.
I want to count the “Yes” in a column if that row also contains a specific email.  But I also don’t want that count to be in a table, just in text (as you will see on screenshot).
Screenshot of what I have tried so far in terms of formulas is below:
              You only need one and.
Try swapping the AND in capitals with a comma.
              Im still getting zero: Current formula im trying is
[All Students Master].[TRI This Year?].CountIf(And([All Students Master].[CM Email]=“sweir@cuhsd.org”,[All Students Master].[TRI This Year?]=“Yes”))
              You could also do filter on table [All studens master].filter(CmEmail = "sweir@cusd.org" and TriThisYear="Yes").count
Also, i see that you are trying to create a summary on top - you could create another view with cm email setup as a group to see only count - that way you would not have to write formula for every new cm email.
              THat worked @Krunal_Sheth! Thank you for the tips
