Strange problem at the moment. In Doc A I have a table that I want to Cross-doc to Doc B.
It has rows but i get the message “no rows were returned when syncing” and I am unsure why this is happening.
Any ideas?
Any ideas?
Ok so in the meantime I did some testing, it seems to only happen when a filter is applied on a certain column in the original table. If I remove the filter (which still leaves some results btw) and sync it works.
I am baffled atm.
HI Remco,
It would be much easier for somebody in the community to help if you share an example.
Regards
Piet
Hi Piet,
Yea but I could not replicate the problem in an example.
