I am running into issues with embedding figma content. Previously it used to work, now when I add the link its a blank embed view. When i expand it, its blank as well, however when i click to be taken to the figma file, it links out correctly.
What am I doing wrong?
I’m getting a similar issue here; it’s showing a logged out state, when I log in using the pop-up, nothing changes…
Hey @FCT , thanks for reaching out and sorry to hear you’re running into some issues with getting Figma embedding to work in Coda. It sounds like this could be related to the way you have your doc or Figma Pack setup. As a first step in troubleshooting, can you please do the following?:
- Clear your browser’s cache and then trying to log in to Figma
- Test this in an incognito/private window. Does the issue persist?
Look forward to hearing back,
Shaina
