Hi Coda Makers! ![]()
(especially those of you working with JSON in Coda - @Math_24, @Max_OBrien, @Eric_Koleda, @Scott_Collier-Weir, @Paul_Danyliuk)
I don’t know about you, but I have been looking for a solution to this for years - trying to find a way to extract the names of keys from JSON objects (not just their values). ParseJSON() works great for extracting values form JSON when you know the key name. But how do you extract the key name?
I finally found a solution!
It turns out that Coda’s ParseJSON() function supports a special JSONPath syntax that isn’t documented anywhere - not in Coda’s formula reference nor in the original JSONPath specification by Stefan Goessner! I’ve searched through all forum posts about JSON and haven’t seen anyone mention this technique before.
The Hidden ~ Operator in ParseJSON()
ParseJSON(yourJsonString, "$.*~")
The tilde (~) character tells JSONPath to return the key names instead of the values! This appears to be a Coda-specific extension to JSONPath or perhaps from a later JSONPath implementation they adopted.
Patterns:
$.*~- All top-level keys$..~- All keys at any level (recursive)$.objectName.*~- Keys in a specific nested object$.[*].*~- Keys in top-level array items
Examples:
For a simple JSON object:
"name": "Bob",
"age": 42,
"address": {
"street": "123 Main St",
"city": "Springfield"
ParseJSON(jsonString, "$.*~")returns["name", "age", "address"](top-level keys)ParseJSON(jsonString, "$..~")returns["name", "age", "address", "street", "city"](all keys at any level)ParseJSON(jsonString, "$.address.*~")returns["street", "city"](keys in the address object)
Why This Matters
This solves so many problems that the community has been tackling with workarounds:
@Max_OBrien was looking for dictionary-like functionality in the “How to create a ‘dictionary’ object?” thread, and tried using the hidden
_Deref_Object()function. -
@Paul_Danyliuk mentioned that there was “no ‘legal’ way to extract a name by value yet” when discussing
Object()and suggested using hidden, unsupported functions. -
In “Unexpected non-whitespace character after JSON”, users were struggling with JSON formatting but couldn’t easily inspect the structure.
@Ratish_Gupta and others have been using the now “sunsetted”
_DEREFfunction for complex data operations as mentioned in “Formula Map Sequence + DEREF”.
