Hi, I suggest custom unit in column number format.
In excel is possible
exemple :
10 °F
or
14500 Pa
exemple :
10 °F
or
14500 Pa
Dear @Math_24 ,
In reply from my mobile device, sorry not being able to give a more comprehensive sample.
It’s possible with format(“{1} PA”, [column with number])
This means that there is no limit on how you can enrich your data.
Yes thank you, it is possible to add a format. But this imposes an extra column.
In Fibery (for example) it is possible to create a specific unit on the column and we can treat it as a number
For exemple in fibery :
can add unit (meter, gramme, …), however can use column for calcul (stay in number type)
