So the new grid feature is great, and I’m hoping that it solves a lot of my problems. But it’s not working with the format() formula. This is the template I want to use:
Then my formula (in another table) looks like this:
But then when I send it in an email, it still has the {1} and {2}. Is there any workaround for this?
it’s a pity that your expectations are not matched.
an alternative is a normal page you reference as your template and you use the columns to outline the values nicely. Maybe that works, I did not try it.
