Hey all,
DISCLAIMERS:
The answer may be complex, so if you good-people are too busy for a detailed answer/instructions, I would love to at least like to know if I would be wasting my time trying to educate myself in pursuit of the desired functionality…
Alternatively, if anyone has built anything similar with external tools that are cheap-to free that would save me from drudgery, I would love to hear about it.
THE PROBLEM:
While I’ve gotten a lot of use of the html pack for embeds etc, my VERY superficial understanding of HTML/CSS/Markdown is preventing me from knowing the best way to start on this.
I have been unable to crack the following :
Given an input of a column of URLS (for example: https://www.technologyreview.com, https://techcrunch.com/, https://adage.com),
Can the HTML pack (in combination with x, y and z) packs/formulae enable me to:
a. Extract updated list of Article links
b. Most importantly, have a lookup table that
1. Follows those links
2. Extracts the article contents into readable text into a coda-cell?
2.a.With the understanding that there may be LIMITED(?) site-specific
code/references, I might have to collect from the source-code of different sites to
make them work.
2.b. Could the html pack enable me to reference the page-source info and
dynamically set parameters with select lists/buttons/toggles that would allow me to
more rapidly configure per-site?
If yes, any pointers/material would be appreciated but not expected.
If no,
What are the:
a. Technical limitations placed by Coda website
b. Technical limitations based on the website: code, format, security -
If so, is there a viable workaround?
