Hello! It’s my first time ever using an API and I wanted to connect coda to other apps (which can be done with it if i’m not wrong), so I guess it’s time to start learning
I have looked at the guide here but I need some help to get things up and running because I don’t really understand how to make it work
I’d love to have links or resources that could be useful for learning to use the API.
If there’s any guide, post in the community that you’ve found useful or general guide about API’s that you’ve used please share it here
Any help is appreciated! Thank you!
