Home with docs as cards
Is there a way to have a homepage that is published which then displayed other docs as cards. For example, I want a blog home page, then I want a heading called recent posts, under recent posts, I would a card view each doc that auto update when a new doc is created in a specific folder?
Hey @Wayne_Simpson1 this sounds doable. If those cards have links to other docs and those doc names change or you add a new link, the links should update as far as I’m aware.
