I have a project table where each project can have dependencies, which are also project (the dependencies column is multi-select lookup that points back to the project table).
I’d like to generate a bullet list of projects that are dependencies for each row in the table. typically I would do this with recursion. I was wondering how I might do this in a formula in coda. Any suggestions?
Thanks. that did the trick. I’ve been able to build lists of dependencies.
Now, I’d like to do something a little different. I want to create a filtered view of the projects such that the view contains the projects that match a criterion(project.team = blah) and those projects’ predecessor projects. I thought I could do with a formulamap, but that is not doing anything for me. any suggestions?
Make a column on each project that lists its predecessors (not bulleted, just like the “Path” column in the example) - maybe you’ve already done this as part of your solution to your first problem.
Then your filter formula is something like:
project.team = blah OR
project.predecessors.filter(currentValue.team = blah).count() > 0
Basically you filter the predecessors list, and see if at least one predecessor matches the team
sorry, I wasn’t more clear. I do have the predecessors in a column (from you earlier answer). Now what I want to do is merge the list of projects with team = blah with each of their predecessors. the resulting list will eventually contain projects where team != blah.
Could you share a version of your doc that shows where you want this to display? E.g. is it another column, or a new view of the table with certain filter settings applied?
I came across this post. Not sure if it’s still relevant for you, but I have figured out a recursive lookup, that makes is possible to make trees/ hierarchical structures.
If you’re interested, have a look here:
