Hi,
currently I am working on a new doc. As users often don’t know Coda, Onboarding is crucial.
In this forum and in Coda emails I often see GIFs (?), which is extremely helpful…
Now 2 questions:
1.) How do you create them?
2.) Can they be easily integrated in a Coda doc?
Thank you,
Thomas
Hi @Thomas_Meissner
There are many options also depending on the platform you are working on.
I am at W10 and using:
https://www.screentogif.com/
A small local file and you can safe the *.gif at the location of your preference
Just with copy past you can add them in your doc
@Jean_Pierre_Traets
Thank you very much. I will try it
@Jean_Pierre_Traets
Is there a way to speed up the GIFs a bit?
My file was 1.2 Mb large and too big for Coda…
Hi @Thomas_Meissner,
In the edit menu and image section, you can:
#) delete frames
#) speed adjustments
#) adjust the size of the image
Like with every program, you need to play around and see what’s giving you the best result.
