Hi!
So, I have a very big table with loads of transactions.
Each row has a date, concept and amount.
I’d like to be able to combine all those transactions into months and make a sum of each month.
(my idea is to be able to visualise how much we spend per month)
I very quickly modified your doc (thanks for sharing ) but I’m not sure this is what you were trying to do
Basically, I just added a months table to your doc and linked that table to your Dummy Input then I gathered back the data from the Dummy Input into the months table to sum the amounts per months …
You could also use a grouped view of your Dummy Input (See Dummy Input 2 in your doc)
Sorry, this is very very quickly made (I’m not really in front of my keyboard at the moment )
