Hi, everyone!
I’m working on database design in CODA, but I’m a little bit confused.
I always know that databases that have a many-to-many relationship always require a junction table to normalize and do some calculation since most databases can’t accept array of list of data.
but CODA can holds a list of data in one column, and can iterate calculation into every data in the list, and adding or removing data in the list is also very easy, very easy that I think I don’t have to use a junction table and everything still work just fine.
So, I’m a little bit confused that when I design CODA database, is it still require a junction table to normalize many-to-many relationship database, or just link rows and code a bunch of iteration formulas to do all the calculation instead?
