Hello guys
Thanks you are here.
Check the embed doc please. Who knows how to crack this task? Please
Hi @Alexey_Demin,
could you please change doc’s permissions so that we can have a look and dig into it?
Thank you!
Thank you @Alexey_Demin!
I got your point.
I think there are no easy ways to achieve that but only with some hacks (and you might accept they could be discontinued).
I’ll have a look by tomorrow.
Hey @Alexey_Demin,
Here’s the solution you’re looking for; indeed it uses some hacks to extract @-references out of the text.
In a single formula that’d be:
RegexExtract(
_Merge(thisRow.Description) + "",
'{[^{}]*?"type":"ref"[^{}]*?}', "g"
).FormulaMap(
ParseJSON('{"val":' + CurrentValue + '}')._Deref_object("val")
And if you need not the bubbles but the @-references concatenated by commas exactly like in your example, do this:
RegexExtract(
).FormulaMap(
Concatenate(
).Concatenate().Slice(3)
@Paul_Danyliuk Thanks a lot. Looks like the exact solution I`m looking for. Formula you provided looks scary : ))) but I will try to understand. Get back with results.
Thank you again
