Ah! I might have another idea
… As I think I misunderstood your request a little
(sorry
The formula I gave you in my previous reply would return and sum all the amounts for the dates within the ranges you set up in your Planner table without taking into account if the amount was paid or not …
So I guess, this might be where the issue is
If you need to only sum the paid amounts from your Payables table, the expression
thisRow.[Start Date] <= [Due Date] AND [Due Date] <= thisRow.[End Date]
… will not be enough in your Filter()… You would also need to tell Filter() to look for rows in your Payables table where the Paid checkbox is checked (i.e.: true)
So the formula would be something like this:
Payables.Filter(
Paid
AND thisRow.[Start Date] <= [Due Date]
).Amount.Sum()
This Filter() formula will go through your Payables table and return the rows where the checkbox Paid is checked (a checkbox being a boolean and having only 2 viable states (true or false), you don’t need to precise the = true here, it’s implied) and the Due Date is within the range
… All that’s left is to access the amounts of these rows and sum them
Now, if you need the opposite …
Payables.Filter(
Paid.Not()
).Amount.Sum()
It will do same thing as the previous one when it comes to the range but it will only return (and sum) the amounts where the checkbox Paid in your Payables table is Paid.Not() (in other words, Not() true, so false
I’ve created a simplified version of your doc based on your screenshots so you could see the 3 different Filter() formulas side by side
The first one in the[All Amount in range] is the sum of all the amounts within the date range regardless of the state of the Paid checkbox in the Payables table.
The second one, is the Paid only (within the date range) and the last one is the not Paid only (still within the date range)
I do not know that
… But I can give you the list though
- = equal
- As in a = b:
a is equal to b
- != not equal
- As in a != b:
a is not equal to b
- > (strictly) greater than
- As in a > b:
a is strictly greater than b
- < (strictly) less than
- As in a < b:
a is strictly less than b
- >= greater than or equal
- As in a >= b:
a is greater than or equal to b
- <= less than or equal
- As in a <= b:
a is less than or equal to b
The magical auto-suggester of Coda should help you with that too when you write certain formulas where you would need one of those
(The auto-suggester won’t necessarily be triggered in that fashion with dates as the auto-suggester tends to suggest anything related to dates in this case
I hope this helps
