Hey. How can I copy EXACT row from one table to another with a button?
How it looks like:
Formula
AddRow(Toplant,Toplant.[Uniq ID],First(unn.c1),Toplant.ID,RowId(thisRow),Toplant.Row,‘1’,Toplant.Column,‘2’,Toplant.[Genotype Name],[T.Genotypes].Name.First(),Toplant.Planted,Today()),ModifyRows(unn, unn.c1, c1+1)
Don’t pay attention on ModifyRows() - it’s for uniq number when adding and it works fine.
What do not work
As you can see I put button in every row. I need when I click the button - the data from the row will be copied to another table.
The problem is with the column ‘Name’:
- I can add a row with only First() or Last() value; or
- All together as an array
I tried to use thisRow(), but it works not properly.
Help me, please
