Summary: Fetcher requests will timeout and retry more reliably, and with more visibility in the logs.
As many developers know, dealing with network requests can be messy. Most of the time everything just works, but occasionally you run into a latency spike or hit a rate limit. If you stop and think about how complex the internet is, it’s amazing it works at all!
The Fetcher service included in the Packs SDK does a lot of work behind the scenes to smooth over these bumps, but it hasn’t been as robust or transparent as we’d like. We recently made some updates that should improve the experience for Pack makers.
Smart timeouts
Previously requests would have a 50 second timeout, to stay under the 60 second execution time limit. However if you made multiple requests in sequence that static limit would break down.
Now the timeouts are dynamic, set just under the time remaining in the execution, so that the request will fail with an error before the whole execution does.
Transparent retries
When you hit an API rate limit and get a 429 response, Coda will automatically retry the request after a few seconds. However those retries were hidden from sight, and made it hard to understand the behavior of the Pack.
We still perform automatic retries, but now each failed request and subsequent retry are visible in the logs shown in the Pack maker tools.
Better rate limit errors
Even with retries, sometimes you just run out of time to wait. Previously when this happened the Pack execution would fail with an obscure error message, which couldn’t be caught.
Now we detect if there is enough time left for a retry, and if not fail the request with the last 429 response that the server returned. This allows you to catch it in your code and show an error to the user.
All of these changes should be backwards-compatible with the code you have today, but if you notice any issues let us know. And add a reply if you have other changes you’d like to see in the Fetcher service.
