Is there a suppoted CODA integration tool for MS Office
We are looking to automatically integrate certain fields of our CODA database into MS Office. Preferably into Outlook as contacts. Thank you
For sure! Codas word for integrations are packs.
You have packs for:
And likely more if you go look at the Coda Gallery! Coda.io/gallery
Thanks for your response Scott. Much appreciated. We shall take a look at what is available.
Regards
Keith
