Logging of unexpected errors
any chance you’ll consider logging “unexpected errors”?
it happens sometimes that i’m trying to get something to work like a button and, after clicking, i’ll see “Unexpected error while trying to execute action”
maybe it’s a security issue on your end so this is a non-started but it might help those of us who are comfortable writing software if we could see some more detail around that error. a simple console log would be fine with the understanding that if you want to work in “developer mode” you just open the console.
Yes, how do we debug unexpected errors without access to more detail? Could you at least show some detail in the browser console?
One of our users is just getting this now (and I’m not!) - so its very confusing. Would love to know more about this.
Yep I have a formula that resolves on the canvas but when inserted into a button:
OK in my case I was able to figure out the problem. I was trying to use an action to modify/hardcode a column value that was set by a formula.
