Is there a max size a document can be?
I have what seems to be a fairly large document:
But, for some reason when we try to use it on mobile or ipad it glitches and shuts down the app. Is there a reason for this, or a work around on how to get this problem resolved.
Dear @Erik_Andersson1,
I know that on a mobile device things can get more tricky in this case.
It’s depending on the connection speed, memory available and the calculations made in your doc.
What I can suggest is to check out this page: Improving performance | Coda Help Center ?
