All good! Should be in the top right corner of your doc under share.
Under Get Link you can change who has access
Excellent, thank you - should be open now.
Nope it’s not. Can you share the link? Make sure it’s open to anyone with the link
Hmmm … I got no idea what I am doing wrong here. I used the embed function under share and made sure that it is open to edit … but apparently it is not yet. How should I use the embed function?
Does the link work?
Yep! The link works! thank you
The columns in your single-row Dashboard Table were text columns, rather than lookup columns. And your view of the Dashboard Table was a chart view rather than a detail view. If you turn the columns in the Dashboard table to lookups, and the view of the Dashboard to detail view, then you can see a chart for each lookup column within the detail view
Hope that’s relatively clear. I edited your sample doc to show you what I mean. I changed the ‘Service Products’ column into a lookup, and displayed it as a bar graph within your Dashboard detail view. Hope that helps!
Though btw, with Canvas layouts incoming, this trick probably won’t be necessary soon
Thanks a lot for your help on the layout!
With regards to the canvas layout coming in: I am part of the beta testing and find it so far pretty disappointing, as it has some limitation (don’t know what I am allowed to write here). I sure do hope that this limitations will be raised in the final version!
I will continue playing with this hack as it apparently has more flexibility, though it is much more difficult to set it up.
Thanks again!
Hey @anon26297861 , maybe you did already but if not: You can share your feedback and especially disappointment with the Coda team! This will help to make this a perfect editor. If you are in the beta, you should be able to type /feedback
to open a ‘Editor Beta’ feedback form. You are definitely allowed to type anything in there
Why is that, @anon26297861?
The only limitation so far is that the 2/3/4-column layout cannot go “full screen” and expand to fill the whole screen. Other than that, it can do everything that the dashboard hack can do, and actually waste less space (e.g. the charts are bigger in those columns vs what you have in detail layouts)
… but that limitation is exactly what I mean. I have a workflow in which I plan for a week tasks via two calendars and that is next to each other simply impossible to do. I will send you a screenshoot via message and you know what I mean …
Yes, I did that, of course - try to be a good beta-tester
@Paul_Danyliuk interesting but a far less able share than can be done simply in excel. I’m dissapointed Paul some great templates in Coda and some use cases but after using for many months I’m back to excel and power query to achieve in far simpler ways what I wanted to do here - even a paste from a pivot table from some data processing in excel to Coda, to share as a live link or website embed, is limited. Open minded and hoping to be wrong just havn’t seen it and spent far too long trying
