More than 4 Decimal Spaces?
Hey Coda Community,
I’m trying to get a way to see beyond the standard available 4 Decimal places that Coda allows in a table. I know you can hover over the cells to see the full number, but it would be really helpful if more decimal spaces were automatically visible without hovering over each one. Has anyone been able to make this work? I can’t seem to find any packs that solve this
Dear @Keap_Ops,
You might consider up voting here;
