Hello,
Is there a way to move several page together into a same doc?
It seems so simple… I do it currently page by page
Thank you in advance.
jB
Hello,
jB
If it is page with subpages, you could use a button with “duplicate page”, with the copy subpages option enabled.
Thank you @Piet_Strydom for the answer.
I notice this option but it is useless in my case : i have more than 100 pages form my notion migration and i have to dispatch them into different subpages. So the ability to multi-select pages seems to be the simplest way… But impossible at the moment.
Maybe i will explore a API solution.
