Need help in creating a refreshing date range filter for a line chart
I made a line chart with the horizontal axis representing Month within 1 year, and the vertical axis representing expense.
The problem is that the current line graph would display the expense in 2025 even it’s 2024, so i wanted to create a custom filter for the graph to only display the current year expense and will update automatically when it’s 2025 and display the relative expense set in 2025.
If your month is based on dates in your table and the date column is called (for example) ExpenseDate, the filter should look like this:
Expensedate.year() = today().year()
