Hello. I’m having trouble coming up with a floating date range formula for the filtering of a table view.
I have a list of rows/items that is ‘Content’ that each have a ‘Publish Date’. Our team has a weekly meeting where we need to view (which I’ve already created) the table of upcoming ‘Content’ based on ‘Publish Date’. I need the view to constantly update to only show items in a three-month window. The view needs to show:
- 30 days (preferably one month) back from “Today’s Date”, and
- 60 days (preferably two months) ahead from “Today’s Date”.
- If possible, extra credit if it can show all the way to the last date of the second month.
For example, “Today’s Date” is 11/29/23. The filter would only show items with a ‘Publish Date’ from 10/30/23 to 1/28/24 (extra credit if the formula goes out to 1/31/24).
Another example, if “Today’s Date” was 12/31/23, the filter would only show items with a ‘Publish Date’ from 11/30/23 (or 12/1/23?) to 2/29/24.
Currently, my custom filter is not static (see red callout box) and I have to go in and manually adjust it every couple of weeks. I need the filter to calculate the above and consistently change based on “Today’s Date”.
I can’t embed my Coda doc due to org policy, but here are some screenshots:
Please let me know if you need any more data or screenshots to help me with this formula. Thank you!
******Supplemental information: As you can see from the screenshot, I created a ‘Month Name’ column if this helps with the formula. I can also create a “Calendar Year” column, if this is needed for the extra credit above to work. Thanks again!
