Note-taking & Bookmarks (chrome extension) - AI tagging, summaries
I built this system so people and teams can collect notes & bookmarks, share them with each other, tag them, find them, and make sweet use of them. There’s AI tagging and note summaries, daily streaks, note templates, and some more.
The doc uses the little-known chrome bookmarking extension, which is pretty slick once you get it set up well.
Check out the tool here.
Check out the full build walkthrough on YouTube.
And AMA me anything if the 2hr vid isn’t detailed enough…
I’m surprised you find the chrome extension slick! It only allows you to select doc/table/title. The fact that you can’t even add a written note or select any values for other columns makes the extension fairly unusable imo.
What other parameters would you add?
I work mostly on desktop so always have the coda doc open in another tab. And all I need is url and title, then I can flip over to the doc and add any context, or just add context later.
If you are going to flip over to the doc anyway, why not just copy/paste the link and skip the extension?
if you check notion extensions either the official or none official you will understand what @AJM referring to.
anyway I liked your optimistic view of the extension, it’s pretty average extension and I wish more functionality comes on it.
