I am hoping someone might be able to explain why this formula -
… only returns multiples of 3. (Note, the image there is just as I have written the formula on the canvas, it’s not part of a larger formula.)
It’s like it is getting a single RandomInteger and then multiplying. What is doubly mystifying to me is that I have used this exact formula in another doc and it works exactly as I expect, I get a value between 3 and 18.
But I wonder if something might be going on in the background of the coda servers because yesterday a formula I had written with a simple If(date1 < date2, … simply would not work correctly (that is, it returned true even when date1 was >= date2) for several hours while I tore my hair out, and then all of a sudden it started working as expected (and no, I hadn’t changed anything, I was simply debugging, for a looooong time).
It’s still going to give somewhat a random result, but like you said, it’s getting one random number, then multiplying it by 3 since you have 3 different randomIntegers().
Every result you get from that other doc should be able to be divided by 3 which will give the single number all 3 randomIntegers() got.
