The formula Random(true) / Random(true)
returns 1 every time.
That must mean that both Random
invocations are returning the same number? That’s a problem for many types of statistical questions. Anyone know how to get around this?
When i need random(), for example when i need to randomize a number for each row, i cannot just simply put in the column formula “Random()” but instead creating a button that write for every row of that table a random number (to be precise a button that press a button in each row), this is seen from coda as a different action every time and thanks to this random is regenerated
Does this help you?
Yeah, my solution is to create an external variable called otherRandom
and put the formula Random(true)
in that. So far that’s working, but if I needed many many instances of randomness this would be untenable.
@Connor_McCormick With my method you can create as much random number as the row in a table
(in case you’ll never need more…)
They are both inelegant workarounds for the time being, but yes, great to have that as an option. Thank you
@Connor_McCormick I believe this is because, when Random()
generates, it is generating once for the row, not once for each instance of the function in the formula.
I thought we might be able to address with with the new WithName()
formula by creating two namespaces, but alas it does not work:
WithName(Random(), r1 ,
WithName(Random(), r2,
concat("r1: ",r1,char(10),"r2: ",r2)
Your best bet is going to be using an action to generate two different random values (whereas I thought WithName()
was kind of designed to solve these types of issues).
Good thought! It really should work that way
