Random(updateContinuously) takes a boolean to determine if it should generate once or be regenerated on an ongoing basis
When compared, False() and false are equivalent – they both return the boolean false.
But when used in the Random formula, Random(false) does not work the same as Random(False()).
You can see this document for details: Random Example
